Home Forum Ask A Member Struggling under load
Viewing 4 posts - 31 through 34 (of 34 total)
  • #240475
    robotmark
      oh that’s an interesting idea. My issue is that the extension pipe is too long by several inches. I could probably cut it shorter and use the rubber splice like you mention.
      #240522
        The water tube extension should fit properly if it is indeed and OEM piece. Perhaps the existing tube needs to be cleaned up a bit with some emery cloth…I don’t know if I would “chance” any alternative tube extending ideas…
        #240528
        robotmark
          That was my first thought too, that a little emory cloth on the outside of the old one and the inside of the new one might do the trick. They should overlap a good four inches, which feels like a lot, but I’ll make it work. It’s interesting that the kit includes a full size drive shaft but not the full size water tube.
          #240536
            I’m “guessing” this is because you probably have to pull the powerhead to replace the water tube…
