Home › Forum › Ask A Member › Value of 1950s Mercury race motor
- This topic has 6 replies, 4 voices, and was last updated 1 month, 2 weeks ago by
kevboy.
September 18, 2026 at 3:16 pm #328702
I am selling this motor and would like an estimate on estimated value
September 18, 2026 at 6:48 pm #328717what is it kg4 kg7 mark20?
September 18, 2026 at 8:44 pm #328719I believe it’s a mark20 but I am not sure. there is no ID plate on the motor. She does seem to have a lot of Mark though20H parts though.
September 19, 2026 at 3:57 pm #328756811-467 Block as seen in your picture. That is Mark 25 I think; although maybe it is unknown what if any alterations have been done to it internally.
Value is a tough thing to establish; even more so if we don’t know who did the work on it and what they did exactly.
I suppose you are asking for a “range” of price.
September 20, 2026 at 1:56 pm #328801The value is in the drive shaft housing & gear. That value is dependent upon the feel of the gear mesh & ratio 1:1 or 16:21.
Chuck is correct it is a MK25 block, probably no pads unless it is a block with the single pad. It has a MK25 flywheel but has a MK 20H Carter N carb. The stacks & filler block, if there is one might be an asset to someone.Depending on the variables mentioned above, price range $800 – &1500
September 20, 2026 at 1:59 pm #328802The value is in the drive shaft housing & gear case. That value is dependent upon the feel of the gear mesh & ratio 1:1 or 16:21.
September 24, 2026 at 5:17 pm #329056Thank you gentlemen for the information. Is there a chart with the block casting numbers listed? I bought this 10 years ago or so and did a cosmetic restoration on it. The seller had no info on it. It does have spark and I got it to pop off on a short blast of spray. It also came with a Ka 2a carb and 3 extra 2 blade props, 2 bronze and 1 stainless sreel. Again thanks for the info!
