Home Forum Ask A Member Washers for Cylinder Head Bolts
  • #181010
      I’m looking for some washers, part #300399, to go with new cylinder head bolts on my QD-20, hopefully at a better price than $3.00 each at Marine Engine. I’ve looked at Fastenal and McMaster-Carr but can’t seem to find anything comparable to the OEM washers. These measure about 0.28 ID and 7/16 OD. Anybody have a source for these?
      • This topic was modified 6 years, 6 months ago by Bob Wight.
      #181016
      Randy in Tampa
        Do have have an Ace hardware near you?🤔 they usually have something close, they carry alot of odd fasteners etc…
        Rotary valve Johnson’s Rule!
        #181019
          Yes, my local Ace Hardware was the first place I looked, since they do have a lot of specialty fasteners. I made a quick pass through there yesterday and didn’t find anything but guess I’ll go take a longer look. Thought there might be another source I hadn’t found yet.
          #182044
            If anyone else cares or happens to be looking for these size washers, I found that a metric M6 washer is equivalent in size to the original factory washer.
            #182096
            2fast4me
              Bob, have you looked into hardware for Aviation? An AN960-4 washer fits a 1/4 in bolt better than hardware store washers. They also come in AN960L for thin.
              Jim
              2Fast4Me
              #182101
                Find smaller washers with the correct OD and drill them out.
                #182102
                  Jim, No haven’t tried the aviation route yet but did some googling after your note and I might try those on a future project. I bought a bag of the M6 washers already and they should work fine – the ID and OD are the same as the factory washers.
                  #182218
                    Bob,
                    there are uss & sae washers. Next time you may try a nut & bolt business for the sae “thin collar” made washers.
                    #182273
                    bob-d
                      Boltdepot.com ?
                      Might want to try. I have used them in the past.
                      Pretty big selection.
                      Bob D
                      #182333
                      aquasonic
                        Last year I needed two 1/4” washers that were missing from a 1954 Evinrude cowl. Regular 1/4″ SAE washers had an O.D. that was too big to fit into the recess in the cowl. 6MM washers worked. They are a little bit snug on the I.D., but they had the smaller O.D. that was needed.
                        Improvise-Adapt-Overcome
