Home Forum Ask A Member Water Pump impeller Scott Atwater 1-16 shift
  • #161260
    KEVIN
      is it better to disconnect the shift cable in the lower unit or where it connects under the power head? taking any suggestions for ease of changing the water pump impeller. thanks, Kevin
      #161278
        Remove the cap from the front of the gearcase. You will find a round “nut” threaded onto the end of the shift rod. Simply remove it (After noting how many threads stick out the bottom for reassembly).
        #161607
          While there remove impeller housing, with a little heat, factory glueed it in & replace D-shaft seal..
