Home Forum Ask A Member Water stops spitting when engine warms up? 1956 Javelin 30hp
  • #82399
    kirkp
      Not wanting to add confusion to this but a question popped into my head. The OP said water comes out the exhaust port. Does this motor have a telltale? I don’t think of this as being the same as the exhaust port but I could be wrong.
      Kirk
      #82403
        No "tell-tale". Water sprays out of the exhaust relief port about half way down the backside. Actually better than a tell-tale unless you just want to watch it pee.
        #82406
          I think Dan is onto something.
          It sounds heat related. Then, for some reason, the heat leads to pump malfunction.
