My 1940 HA-15 Johnson 2.5 hp tested a 60# on both cylinders in a compression test. I would think that is pretty good but I don’t have any info that says otherwise. Any suggestions?
I have a 9.5 turtle that runs fine at 65 psi PSI are very subjective .. different meters different rseults…. and if the engine run well after 86 years I would not be to concerned.
compression never really matters as long as the engine is getting intake compression and the motor is running, although it might not idle very well if it has super low compression.
