Home Forum Ask A Member Which nipple was used for the double hose pressure tank?
  • #165244
    Jeff Barsch
      I will block the nipple with the red arrow with a vacuum cap or take out nipple and put a screw in or solder it closed{content}
      Looks like you could unscrew the red nipple and replace with a brass plug, then you never have to worry about it leaking.
      1954 Evinrude 7.5 HP
      1954 Evinrude 15 HP
      1954 Gale 12 HP
      1955 Johnson 10 HP
      1956 Johnson 10 HP
      1956 Gale 12 HP
      1956 Evinrude 5.5 HP
      1957 Johnson Golden Javelin 35
      1958 Johnson 7.5
      1960 Evinrude 18 HP
      1973 Johnson 6 HP
      #165247
      outboardnut
        I tried purchasing a bolt for that hole.But the hardware store did not have that type of thread.So I solder the nipple closed.
        #165294
        Jeff Barsch
          It would be a plumbing thread. Sounds like you got it sealed up though. Keep us posted when you get it running!
          1954 Evinrude 15 HP
          1954 Gale 12 HP
          1955 Johnson 10 HP
          1956 Johnson 10 HP
          1956 Gale 12 HP
          1958 Johnson 7.5
          1960 Evinrude 18 HP
          1973 Johnson 6 HP
          #165780
          opposedtwin
            Just out of curiosity, why are you switching to a single line tank? I assume you have access to a decent pressure tank. Not judging, just have always wondered why people convert.
            Scott
            #165784
            outboardnut
              opposedtwin- I think going to a single line will make it more saleable
              I know I will not get my money as to how much I put into the motor but at least I can sell it and not have it sit.
              Then use that money for new project.
              Other things I am doing to the motor-
              It will have 12 volt starter solenoid under the hood.But keeping the 6 volt starter
              Converted from pointy tooth cog to ball tooth cog on tiller
              Installed a kill switch
              Updated the lower crank shaft seal to carbon seal with quad ring
              honed cylinders and new rings
              that’s just off the top of my head
              It will have original patina
              I hope who ever buys it will run it hard- like it was meant to
