Home Forum Ask A Member Johnson TN 26
  • #79711
    ford981micah
      Thanks aquasonic I had missed that test on the pochefamily website. I will give it a try.
      #79721
      ford981micah
        I took the check valve out it is clean. The compression on the top cylinder is 65 and 68 on the bottom. I did notice that when I turn the throttle the lever on the carburetor stops moving when the throttle just gets below half throttle. It will idle there and is very slow like it was on the HD-25 that I had. I wonder if the throttle position is off?
        #79729
        ford981micah
          Video of the throttle linkage.
          https://youtu.be/4I0cEw0Ei8U
          #79738
          ford981micah
            Well, it is working right now. It idles down like it
            should. Now, I need to get the recoil fixed and it is ready to go for a ride. Thanks for all of the help.
