Home Forum Ask A Member Prop help
  • #10631
    RICHARD A. WHITE
      Found a prop, why I bought it??? No clue but has TB40 stamped, 2 blade aluminum, uses pin. Not seeing it in the MW database online? And not showing up in our database either…
      classicomctools@gmail.com
      #79920
        TB40 is for Johnson Evinrude Gale 25-40hp cheap tackle box prop bolt on pin drive.
        #79927
        RICHARD A. WHITE
          Wonderful, so used as an emergency prop…thanks btw, where did you find that info? I googled the heck out of it, even found another one on Ebay, but that guy did not know what it was either…
          #79930
            Found in second edition prop book by member Arnold Cohn. His info. was from Michigan Wheel catalogs 1946 to 1969.
            #79943
            RICHARD A. WHITE
              ???? I looked thru our MW data base and nothing showed up? Interesting Again, thank you
