Working on my 7514 Fleetwin 7.5hp (1954) I ran into something I had not seen before.
The rod appears to be brass. It is very soft. In this particular outboard the rod had apparently been abused by previous owners. The rod is bent everywhere. The threaded area is bent over at angle. Several spots along the length have deep gouges.
I checked my parts bin and I do have a 7522 (1957) Fleetwin shift rod. The 54 and the 57 are the same part numbers. The 57 rod is steel.
After working on countless mid 50s OMC outboards, this is the first brass on I have ever seen.
How long did OMC use the brass rods? Did they discontinue due to the softness of the metal?
Thanks,
Drifter
