Home Forum Ask A Member Caille Neptune Gas Tank Repair?
Viewing 10 posts - 41 through 50 (of 95 total)
  • #224240
    JOSEPH BRINCAT
      Buc, I would do the bottom to the sides complete, all soldered and then attach , rivet and solder the brass pieces. When you say “crimp” , if you mean the inner “s” bend, I did not crimp any of those joints before soldering, however I suppose that it might be a good thing while you can access them on the bottom panel.
      Your work is looking very good…
      Gas cap>>> the raised “blade” is the correct style.
      #224270
        #224271
          Joe, with the way you suggest, I could do some soldering inside the tank
          as well to increase my odds of no leaks. Yes, by crimping I meant
          tightening the joints up mechanically before soldering, hammering
          the small “fold”, locking the side panel tighter.
          Maybe I’ll start on a gas cap tomorrow if I have some round stock
          the correct size.
          Thanks!
            Tubs, I can see with the motor in your photo, your idea would be excellent
            as it’s a shoret and rigid connection between the tank trough and mixer,
            but my Caille is connected with about 6″ of fuel line, so the placement
            of the trough isn’t that critical.
            olde
              Buccaneer, Hope you can help me!! I have a 1932 Neptune ob5. I have Know idea of its starting procedure, would You know how to start this??? Not sure how to set the points? Any idea of what the replacement ignition condenser would be? Replacement Coil? I would appreciate any help You can provide me or any direction to go from here. Thank You. OLDE!
              #224330
                Olde, Suggest you start a new thread and include photos if possible.
                I think you’re talking about a twin, opposed cylinder?
                I believe some of these had the troublesome Eisemann coils,
                that are NLA, but a lot of time the coils can be retrofitted
                with another brand of coil.
                This is a photo of my 1936 OB34A Neptune with the Eisemann coil.
                Is your similar?
                DSCN4838
                  I got a start on making the gas cap for the Caille Neptune today.
                  It appears that I’ll need a 1-3/8″ hole saw to cut the hole
                  in the top tank panel for the brass gas cap flange to set into the tank.
                  Also appears that “need” and “have” are two different things.
                  I’m making the gas cap out of aluminum, as that’s what I had.
                  I’m glad I thought of making the cap before I soldered the flange
                  on the tank, as I used the flange to test my thread turning as I
                  went along.
                  FYI, the threads on the cap are 1-1/4″ x 14 tpi. Not a standard bolt size
                  according to any charts.
                  DSCN9901
                  DSCN9900
                  It’s 2020 and hacksaws are still used….. who woulda thunk.
                  DSCN9904
                  My “Old Fashion” Milling Machine. Will finish the cap tomorrow.
                  Me and the Flat Bastard had enough for one day.
                  DSCN9906
                    Buc – another nice piece of work. This tank will look great when it’s done!
                    #224361
                      Bob, that will depend on how the soldering goes. I haven’t used
                      a blacksmith style soldering gun since 10th grade. I do have
                      a flea market electric one though, that I forgot I bought several
                      years ago…… will finally get to try it out once the solder and
                      flux arrive.
                        I finished up the gas cap, at least for now. I could make it a little
                        nicer looking with more filing, sanding, etc., or I could hope I
                        get a milling machine in this lifetime to make a new one.
                        Then I cut out the hole for the filler cap threaded flange
                        using an adjustable hole cutter. I had my doubts, but
                        I cleaned the tool up, sharpened the cutter bit, and
                        did a test drill in some scrap. The hardest part was trying
                        to get everything clamped down good on the drill press.
                        Had to do a little deburring, but the flange fit tight.
                        Next, onto the “vent”. My old vent barely stuck above the
                        top of the tank.
                        Is this how they left the Caille factory?
                        I see that Joe’s tank was the same.
                        Some other photos it appeared that the vent line stuck up
                        a ways. I decided to make it longer, figuring I could always
                        shorten it if needed. I could not find any 1/8″ OD copper tubing
                        laying around, but I had a loose carb off a Zephyr with a
                        slightly smaller OD that became a donner.
                        Next I need to “test mount” the tank to the motor to position
                        the bronze mount to make sure the tank looks square
                        to the motor, then drill the rivet holes.
                        I still have to experiment with the rivets after I fashion
                        some kind of tubular rivet set.
                        DSCN9907
                        DSCN9908
                        DSCN9913
                        DSCN9912
