Home › Forum › Ask A Member › Solved – Can’t drop lower gear case 1957 RDE-19
- This topic has 16 replies, 6 voices, and was last updated 3 months, 4 weeks ago by
JOSEPH BRINCAT.
July 9, 2026 at 8:02 pm #324178
now the work begins. Try to do a compression test before spending big$$$… if ok and near equal… onward to electricals
you will need the pull the flywheel inspect coils for severe cracks, replace both coils & condensers….. points may be ok if burnished and cleaned. new plug wires 7mm metallic strand wires only etc.. etc..
great great hobby and lots of help here to bring it back to life ( dump gear case oil check for water ingress. refill. some seals may be leaking pull the prop check for mono wound up on the propr shaft destroying the seal.. resealing is tricky but after a few it is ok. Some folks just change oil mid season if the leak is not to bad. Pressure testing with soapy water will locate the leak in one of 3 places usually #1 prop shaft seal #2 shift rod seal #3 driveshaft seal under the water pump.
the johnson manual I linked contains all you needto service it plus utubes galore to help out.
for parts.. select your model
1957 Johnson Evinrude 35 hp Outboard Parts by Model Number
y
July 10, 2026 at 12:54 pm #324196I’m confused, just which bolts/screws did you remove?? You mention six bolts “at the bottom of the gearcase bullet”. I sure hope I have misunderstood. Removing those screws along with the shift linkage thru screw will allow the skeg to come off the gearcase, something you sure don’t want to do.
I’m hoping you have been able to remove the gearcase assembly and that I have misunderstood. D
July 10, 2026 at 1:12 pm #324199I’m confused, just which bolts/screws did you remove?? You mention six bolts “at the bottom of the gearcase bullet”. I sure hope I have misunderstood. Removing those screws along with the shift linkage thru screw will allow the skeg to come off the gearcase, something you sure don’t want to do.
Sorry, no it’s all good! It wasn’t the skeg / bullet.
I removed the 6 bolts, the bottom bolt in the brass coupler to release the rod, and the large through bolt at the rear.I will be taking apart the skeg if I have good compression. Soaking the cylinders now, as they are seized.
July 10, 2026 at 8:48 pm #324203I will be taking apart the skeg if I have good compression. ^
if gc compression is ok no water…. suggest you do not open it replace oil only
July 10, 2026 at 9:02 pm #324205I will be taking apart the skeg if I have good compression. ^
I had a shot glass or so of pure water in my lower gear case. I’ve got a seal kit on the way to redo it.
July 11, 2026 at 9:04 am #324246see several utubes and johnson service manual !!! redo pressure test after assembly !!
July 15, 2026 at 3:34 pm #324537It’s often said that “nothing succeeds like success”
Congratulations
