Home › Forum › Ask A Member › Coils/Condensers
  • This topic has 2 replies, 3 voices, and was last updated 6 years ago by Tubs.
  • #217282
    terriblecj
      What is the output of the average outboard coil? As in, what would you be seeing on a meter? Also, the case of most condensers is the ground?
      #217285
        Never measured the high voltage but yes the capacitor case is one terminal to ground. I have a high voltage probe but I don’t think it’s fast enough to measure output of a coil.
        Check your secondary winding resistance & refer to a chart for your magneto.
        #217291
          • This reply was modified 6 years ago by Tubs.
