Home › Forum › Ask A Member › Elsgin Sears Elgin 5.5 571.58611
- This topic has 14 replies, 4 voices, and was last updated 4 years, 9 months ago by
seahuntboater.
June 16, 2021 at 10:37 am #240378
Picked this up about a week ago. Got the carb sorted out and the spark too (points were not sliding and were just dirty)
Greetings. Does anybody have a schematic of this motor? I am trying to determine where the impeller is and don’t want to force anything. I opened the gear case and removed the horseshoe clip. Took the nut off the plate also. Seems like it should just slide down now. There is a screw hole on the port side above the cavitation plate that had no screw. Is it broken? I see something still down in there. Also does this take straight grease or the engine assembly grease, etc.
thanks
Ralph
June 16, 2021 at 6:41 pm #240414Does it have neutral clutch, full FNR gear shift, no shift at or what?
June 16, 2021 at 7:58 pm #240423Hey Frank,
It has no gear shift or clutch. Just pull and hope she is pointing in the right direction.
June 16, 2021 at 9:04 pm #240427You have a ’47 5.5-hp, according to my little bible. The closest parts list I have is for a 1950 5-hp, which I strongly suspect used the the same lower. It shows a tall skinny impeller on the lower driveshaft in the vicinity of the cavitation plate. I can email some pics if you want them – this site and I don’t get along , picturewise.
June 17, 2021 at 4:53 am #240440Thanks. you can PM me the Pics of the schematic.I have troubles too with pics. It is the size. Here is a link to the motor and leg pics.
https://www.amazon.com/photos/shared/Mr_n-6O7SU6625QaaGkAYQ.B0YnI9CcjtIzoSDze6pLpb
What is the proper lube? It had grease and a little water.How to get that cavitation plate to drop to get at that impeller? I have to determine if the screw hole still has a broken screw in it or I am looking at some other metal.
Ralph
June 17, 2021 at 8:27 am #240444Prepare to be boarded!
June 17, 2021 at 8:28 am #240447Prepare to be boarded!
June 17, 2021 at 8:51 am #240450Thanks Buccaneer. Seems like I have the early direct drive. I still do not see what is holding the cavitation plate and section below it to the leg so I can access the impeller. If you look at my picture you will see the hole I am talking about which is threaded. I do not see this in the drawing view. What does that screw do? It is possible it is broken inside and is holding together the sections? Note that when i removed the horseshoe clip on the prop shaft that the gear slides easily so it is not holding anything.
I am almost there. If you want to communicate better and have the part description of early direct drive that will help so I can name the parts better.
thanks
ralphJune 17, 2021 at 8:58 am #240451If this has the sliding vane impeller is that rubber? if metal then should I even bother worrying about it until I see if water is pumping or not?
What is the gear lube please?
June 17, 2021 at 1:19 pm #240470Thanks Buccaneer. Seems like I have the early direct drive. I still do not see what is holding the cavitation plate and section below it to the leg so I can access the impeller. If you look at my picture you will see the hole I am talking about which is threaded. I do not see this in the drawing view. What does that screw do? It is possible it is broken inside and is holding together the sections? Note that when i removed the horseshoe clip on the prop shaft that the gear slides easily so it is not holding anything.
thanks
ralphThat forward side fastener that holds the gear case on may be a super long bolt with
some type of nut up toward the swivel pin by the transom clamp…. can’t remember
for sure, but seems like I’ve “been there, done that”.The sliding vane impeller is a flat, sliding “carbon” vane, if I remember correctly.
I do not believe any of these Elgin’s had a metal impeller.Prepare to be boarded!
