Home › Forum › Ask A Member › Evinrude 4423, water pump
  • #326043
    DAVID KELLEY
      Thanks for that info tjlumpkin. Nice looking impellers!  I don’t think that plate can be re-secured.  I’m looking for a replacement.
      #326080
      Gary H.
        David- If you can’t find a replacement, why not try to repair your original one. Drill a hole where the rivets or pins are and tap fine machine screw threads. Install pan head brass or stainless screws to hold the plate down. You can even use lock-tight or epoxy on the screw threads to make it a permanent bond.
        #326171
        DAVID KELLEY
          Great suggestion, Gary, thanks for looking so closely at this situation.
