Home › Forum › Ask A Member › Evinrude Ignition Coil Test
- This topic has 14 replies, 5 voices, and was last updated 6 months, 2 weeks ago by
JACQUES.
April 29, 2026 at 3:57 pm #317079
Looks great, your tool will probably be more sturdy than the actual tools. You can always shave half of a section of that tube off and use it for an installation tool. Now you just need to find something to fit down inside the sockets to push them out!
April 29, 2026 at 10:50 pm #317114
Way to go Bob. There is lot of satisfaction in making your own tools and coming up with a solution. Its similar to solving a puzzle. Not everyone has a mind for it.
April 30, 2026 at 7:24 am #317132To release those pesky clips I have resorted to taking a 3 inch finishing nail and hammering the tip flat. Grinding the side away allows the new;y flatten “spatula” to slide over the hook and release the connector.
April 30, 2026 at 5:33 pm #317179
I picked up that piece of brass tubing I had and thought it might just work. It fit perfectly over the pin and it was indeed very satisfying to see that pin back right out. I think I can come up with a way to slice the tubing in half and make a “push” tool to insert the new coil pin into the plug.
I had a similar idea to start with and tried a small jeweler’s screwdriver to push the pin out and it just didn’t seem to work. I figured I needed something that could fit entirely over the pin and tried the tubing.
"Every time you remove a broken or seized bolt an angel gets his wings."April 30, 2026 at 6:59 pm #317193yes some pins have lateral hooks and tubing is needed to slide over both if you wantto compress 2 at a time.
