Home › Forum › Ask A Member › Gas Tank Crack – TIG Weld Repair?
- This topic has 13 replies, 7 voices, and was last updated 2 months, 3 weeks ago by
Tubs.
August 13, 2026 at 12:08 pm #326249
Another question:
My 1939 Evinrude Elto Cub has a hairline crack in the gas tank that leaks. The crack is near the base of the gas tank neck where it meets the brass ring.Is the best fix for this is to have it TIG welded? There is a custom classic auto shop near me that does TIG welding. I will eventually paint the exterior of the gas tank down the road.
thanks Tim
August 13, 2026 at 12:35 pm #326252Would a better option be JB Weld TankWeld?
Not sure how well JB Weld TankWeld works, how well it seals, and how long it lasts?
August 13, 2026 at 12:57 pm #326256JB Tank Weld Putty another option? Does this work?
August 13, 2026 at 1:11 pm #326260Use one of the gas tank sealers, that seals the tank from the inside out.
I use the Kreem brand that works well.Prepare to be boarded!
August 13, 2026 at 4:45 pm #326266That is a steel tank, correct.. not a good candidate for welding in that location. The brass “ring” was likely soft soldered in pllace. The best permanent fix is to solder the split. However as the split is up at the very top , any little dab of filler would be fine… or just keep the tank half full
August 14, 2026 at 12:09 pm #326323I have a 6 gallon external tank that had a split in the tank bottom from someone slamming in the gas nozzle. A radiator repair person soldered over the crack and it has held up for years. Soldering is good as temperature is low and no ark or flame. Most people do not like welding on a gas tank however empty.
August 14, 2026 at 12:32 pm #326325
The tank is steel and the filler neck is brass so it cant be welded. It was soldered in originally and although the others suggestions would work if done correctly, re-soldering is the best repair if you can do that or have it done.
August 20, 2026 at 4:45 pm #326804When looking for a good soldering shop, who does that kind of work? I’ve got a couple older tanks that need repair but it’s outside of my skill set.
August 20, 2026 at 5:17 pm #326806When looking for a good soldering shop, who does that kind of work? I’ve got a couple older tanks that need repair but it’s outside of my skill set.
Older guy at a radiator repair shop perhaps.
August 20, 2026 at 10:03 pm #326811
You will need to clean the tank real good, inside and out, to get rid of all the gas and oil before you go.
