Home Forum Ask A Member Johnson CD-14 Frozen Pinion Gear-Shock Absorber
  • This topic has 44 replies, 11 voices, and was last updated 6 years ago by Don.
Viewing 5 posts - 41 through 45 (of 45 total)
  • #195426
      Don’t forget that the threaded tips that fit into the gearcase are sold separately by Stevens Instruments…You don’t have to buy the complete gage assembly. The price of the tips is very reasonable also…
      #195428
        I picked up a suggested ” gearcase oil pump kit” at Canadian Tire which came with 2 fittings for 12$ cdn so I have an extra pump and spare tip for Mercs… I think
        the kit ” tips” hare jointed (flex a bit) and not suitable for pressure testing imho so I “glue sealed” the nipple& rim and JB welded the thing stiff …… it now works perfectly 🙂
        I have an alternative option to my crappy hand pump and will be testing next week after my .. winter chores are done 🙁
        #195431
        James Tapscott
          Thanks Fleetwin, crosbyman. So on the Stevens Instrument site its called a “lube tap”. $16.25. Any other suggestions for a decent pressure pump that doesn’t cost a fortune? The Stevens pump is $140!!
          #195472
            https://www.youtube.com/watch?v=lnhZFn5gkG4
            here is what I tried… to use but my unit was no good has explained above but….. it remains a cheaper alternative if I can get mine to work
            hopefully my supplier will ship me a good one !! it does pressure and vacum tests 🙂
            shop around I am in Canada
            #195479
              Whatever pump you decide on must be able to read low pressure/vacuum readings accurately, 5-7PSI…
