Home Forum Ask A Member Lower Unit removal Merc 450 1962
Viewing 3 posts - 21 through 23 (of 23 total)
  • #194129
      you are correct about speaking in person can be easier.
      my # is there for anyone to call.
      #194287
        The bolt that holds the pinion gear on the DS has a very thin head for clearance. Take a 6 point box end wrench & file it flat on the contact side for full contact on the bolt. Many have been stripped using a 12 point & not flattening the bevel. Be sure to use loctite on the threads during assembly. Watch carefully for shims & don’t bend or lose them. They hide on the gears.
        Good luck,
        #250349
        Samuel Phelps
          Is there any other source for seals and gaskets other than M/E .com
          Specifically the upper water pump housing gasket ?
