Home Forum Ask A Member Mark 28
  • #72152
      It just struck me that, if the lower unit is missing, you’d better look up inside the hole where it goes and make sure there is a transmission and water pump. (If the transmission is there, you won’t see the pump because it’s above the tranny; but it is likely there.) Those parts are getting harder to find and a little more expensive, and would thus affect the purchase price. Dave probably has those too…
      #72165
        Bill,
        You are so correct. Look to see if it has the 2 shift spring forward cover is there
        & remember a 200 prop will run backwards, opposite rotation,
        Other red flag is be sure it doesn’t have lower H.P. trans too 4 show, Dave has helped me more times than I can count!!
        #72172
          lower HP trans is only in the mark 10. don’t worry about that.
          #72211
          punchbug
            New swear words…I thought I had em all covered!!!!!1 I am in for that reason alone! It will be my easter present to me LOL
            #72212
              Just remember to have water up to the lower dyna float mount before starting.
