Home › Forum › Ask A Member › Mercury KG7Q
  • #317746
    Aidan Smith
      Yep. It’s got a B Quicksilver high speed gearcase. I know they’re different, just have to find a few.
      1952 Blue Streak "B-Stock Runabout" - 1952 Mercury KG7Q
      1955 Feather Craft Vagabond - 1956 Mercury Mark 55E
      #317747
      Aidan Smith
        It also has the bronze bushing on the propshaft rather than the bearings
        #317751
        RICHARD A. WHITE
          Austin Duggan, Steve Roskowski, Rob Lauer…. any of the racer guys will know what and where to get an impeller. Those guys are all members…Steve rebuild the cases so..
          classicomctools@gmail.com
          #317778
          Dale
            Aidan, if you are getting a backfire it could be a condenser problem.  Intermittent spark causes  popping and farting something awful!  FYI the racer guys that run these old Mercs like to run the timing advance at full advance and control speed with a separate control to the carburetor.
            dale
            get’em wet….don’t let’em set!
            #317813
            Aidan Smith
              That’s possible. I haven’t replaced the condensers, but I did find that there was a slight oil slick on the underside of the magneto rotor, which makes me question an old fuel leak or a bad top crank seal. I will try condensers first. It has the Bendix Scintilla mag, and it was running poorly on one cylinder for awhile, and then I cleaned and reset the points.
              The only other question I would have is the fact that it ran great for 10 minutes or so before the backfiring started. It was like a switch flipped, rather than a slow change.
