Home › Forum › Ask A Member › Need help unseizing a lightfour
  • #332157
    Gregory Geurts
      I got a Lightfour Imperial a while ago, tore it down, and the head has been soaking for a month and a half. I’ve finally decided to unseize it, but the spark plug holes are angled, so a wooden dowel won’t work. Does anyone have any ideas?
      JGG13
      #332197
        Sorry, sure wish I could advise, but this looks like a near impossible situation.  I guess you could try to remove those cylinder jugs, but even that will be tough if the pistons are stuck.
        #332200
        RICHARD A. WHITE
          Heat and some form of penetrant…
          And lots of patience
          classicomctools@gmail.com
          #332204
            it is the old ball and loop physics question … will heat or freezing   expand the cyl. and release the bind on the rings
            which is best ?  …answer…..   try both   based on the AI reply below it would d seems that the cyl. walls will expand outwards releasing the rings… maybe
            Q:   in the physiscs ball and loop example heating the ball prevents it passing in the loop but if heat is applied to a metal ring does the ring it expand inwards or outwards
            *:first-child]:mt-0 [&>*:last-child]:mb-0 [&>*:last-child]:mb-0 [&>ol:first-child]:mt-0 [&>ul:first-child]:mt-0″ dir=”auto” data-selected-text-overlay-target=”_r_87_” data-markdown-text-style=”assistant-message”>
            A:  The metal ring expands outwards AND inwards when heated — but importantly, its inside diameter also increases.
            This is a classic physics principle called thermal expansion.
            Think of the ring as if it were made of a solid metal disk with a hole in the middle.
            When heated:
            • The entire disk expands.
            • The hole expands as though it were filled with the same metal.
            • Therefore, the inside circumference gets larger, not smaller.
            A simple way to remember it:
            If you heat a metal ring, the hole gets BIGGER.
            That’s why in the ball-and-ring experiment, heating the ring would actually make it easier for the ball to pass through!
            #332212
            CHUCK
              Does a Lightfour have bearings as opposed to bushings?
              #332370
              wedgie
                Go to aliexpress and search Zerk to 14 mm.  Assuming the lightfour takes that thread.
                I would go easy on it for fear of bursting something.
                EDIT: AI says its 18 mm.
                #332545
                  Make an adapter for the spark plug holes and use your grease gun to fill a cylinder with grease. This will only work if the piston is high enough in the cylinder to cover the intake and exhaust ports though.
                  A grease gun can develop a lot of pressure so this method might cause more harm than good. By that I mean a cracked cylinder.
                  Sorry Wedgie, I didn’t see your post before I posted this.
                  Great minds think alike eh?
                  #332572
                  wedgie
                    20261119_1629511
                    #332574
                    wedgie
                      Hey Mumbles! Good point about the intake and exhaust ports.
                      #332576
                      JOHN D.
                        In addition to using the zerk fitting trick, try to get lubricant on the backside of the piston. Probably all that’s needed is to break the rings free that are rusted to the cylinder wall. Before getting grease into the cylinder, fill the cylinder with oil or a penetrant. It will be easier to clean out once it’s unstuck. You should only break the piston loose, and then rock the flywheel back and forth to free it up the rest of the way.
