If you decide to do this, the cylinders need to be unbolted from the block. The cylinders are in pairs, so you’ll have to go back and forth between them, unless you’re sure only one is stuck. Soak some paper towels in oil and stuff them in the cylinders. Saves a lot of grease, the pressure may push some oil down around the pistons, and makes clean up much easier. Depending on the design, you may be able to make plates to block the exhaust ports. I use flat bar stock you can get at the home improvement stores. If you weld you can make this with a nut and a old sparkplug. It will be a pain going back and forth but you can apply more pressure than with a zirk,
