Home Forum Ask A Member Questions for the ELTO experts
Viewing 10 posts - 11 through 20 (of 29 total)
  • #172617
      • This reply was modified 4 years, 11 months ago by Tubs.
      #172643
      hollerdog17
        Thanks! Answered my question so I should be good to go. BTW, what do you use (for a fuel line) connecting fuel tank to carb? Mine has a mangled copper line that I want to replace. Possibly a flex tube (reinforced fuel line) arrangement with pressed on fittings that screw into the carb & tank fittings. Your solution…?
        #172658
        lyks2tinkr
          The original fuel line was copper.
          Your motor looks like a nice example of an early Elto Cub. Using a reinforced fuel line would look very out of place IMHO.
          Just as a note, if you ever pop the flywheel off be careful with the spark plug wire. The attachment point on the coil is a known week spot and many if not most Cub coils are open because of this.
          Does the motor have spark?
          #172674
            • This reply was modified 6 years, 10 months ago by Tubs.
            #172687
            hollerdog17
              Good advice, again! Removing and replacing it with something more functional is where I’ll go. You have any tanks so modified to share a picture of?
              Of note, the motor will be shipped from SoCAL to No. WI next summer for use on a canoe. Probably the first time on the water in decades!
              #172700
                #172714
                eviltwin
                  What would it weigh approximately? Might be too big/heavy for a canoe. Be great on a rowboat.
                  #172717
                  lyks2tinkr
                    An Elto Cub is extremely light weight . Lot of them were used on canoes. At 1/2 hp it will move you but if there is a stiff breeze you may go backwards 🙂
                    • This reply was modified 6 years, 10 months ago by lyks2tinkr.
                    #172731
                      Cub-ad
                      #172748
                      eviltwin
                        Ah, my bad, the OP was talking about a Senior Speedster, I confused him with you and your Cub. That will fit great, as you say, and they are a sharp looking little motor. To overcome the wind, Tubs could run two or three of them at a time. 🙂
