Home › Forum › Ask A Member › Top Cover for 1968 Chrysler/Sea King 7.5 HP
  • #332349
    CHUCK
      Is the PDF larger than 8MB?
      What sort of error message (if any)  is the site displaying when you attempt your upload?
      #332359
      Kent Cochran
        It is 2.96 MB
        Maximum file size allowed is 8 MB.
        NSea_King_Mdl_VWB_52179_Prts_Manual
        No error message.
        <label> Select File </label>
        Size: 3031 kb, Extension: PDF
        <label>Caption…</label>Set file caption
        Select File
        <label></label>
        Kent Cochran
        1949 10 hp Johnson QD-10
        1951 5 hp Johnson TN-27
        1952 10 hp Johnson QD-13
        1956 7.5 hp Evinrude 7520
        1957 7.5 hp Evinrude 7522
        #332361
        Kent Cochran
          I changed the file name and it worked.
          Kent Cochran
          #332408
          CHUCK
            Kent…here are some pics of the cowling I have.  I talked to Member Ben Dittmar just now  (Chrysleroutboarddude on youtube).  Ben says that it should be the same cowling as your motor is a Looper as is (was) my 6 HP.
            My cowling is in good shape with one repair done on the side.  A little bondo and a quick sanding and it should be fine for your paint and decals….assuming you will do all of that.
            Chuck
            #332422
            Kent Cochran
              Chuck,
              That is good to know that it will fit. I would love to have the Cowling if I can get it running. What are you asking for it? Here are the pictures of the motor you requested. It had to make a trip to the carwash first. It was home to lots of Mud/Dirt Dobber Nests. All the parts look to be there except the tilt lever rod, it’s not frozen up though. Like I said earlier, I have not started working on the motor yet.                                                          Wish me luck, this is my first Chrysler motor to work on!!!
              Thanks all your help, Kent
              IMG_5709
              Kent Cochran
              #332425
              Kent Cochran
                It’s only letting me send one photo at a time right now.
                Kent Cochran
                #332469
                CHUCK
                  You have one of the best running 7.5’s ever made.  The Chrysler Looper.  Let’s hope that there are no “fatal flaws” that keep you from getting it back on the water.
                  Maybe by the time you get the motor running you will find a cover closer to you at a meet.  My cover is not going anywhere; but you’d have to pay shipping from the west coast.  Unless you want to wait until next July when I drive back to Constantine for the Super meet.  I could bring it with me.
                  Keep me posted.  I noticed yesterday when I posted my pics that I could only post one.  Then;  I “edited” my post and it was happy to accept two more.  A web glitch I suppose.
                  I’m in the directory if you want to talk about it.
                  Chuck
                  #332536
                  Kent Cochran
                    Chuck, I was browsing the directory so that I could add you to my contacts. There are three Chuck’s, which one are you?
                    Looks like I might need that Cowling after all.
                    I would like to give you a call tomorrow if you have time. I am also in the directory give me shout any time.
                    You want believe this, I went ahead and finished cleaning the motor. I then decided to check Compression, Spark and did a fuel pop test. it fired up. I’m shocked!!!
                    I Went ahead and connected my fuel tank directly to the fuel pump and primed it up, had no leaks. Tried starting it with my drill, it started and idled pretty dang good. I’m still in shock!! But it was not pumping water.
                    Tomorrow I will be researching on how to change the water pump impeller. The pull starter rope will not retract back onto the spool. I have to roll it up manually.
                    Thanks for all your help, Kent
                    Kent Cochran
