Home Forum Ask A Member upper crankshaft seal source,66 3hp Evinrude
  • #260148
    solofly
      Looking  for a replacement source for an upper crankshaft seal for 1966 Evinrude 3 hp folding motor. Thanks.
      #260149
      outboardnut
        solofly
          Thanks….is the crankshaft seal in the parts list labeled differently? Nothing called a seal is listed. Did I miss something?
          #260164
          labrador-guy
            Solo there is no seal on the top only a slinger.   The slinger diverts any gas oil mix that gets by the bearing to a duct that is connected to the carb side of the reed valve.  That duct must be open so the intake vacuum can draw the excess gas to be re burned.   This is OMC’s oil pumping system, to get extra lube to the main bearings.
            dale
            #260281
            solofly
              Thanks, That’s correct. I found a photo showing slinger with an O-ring on top. Is the O-ring generic…have to pull & try to match or is it common to other engines?
              #260291
              labrador-guy
                Solo I should say that most of the old motors that I have had apart had a bushings on the crankshaft.  If there is an O ring it is usually between a roller bearing and the engine case.  An O ring will not last long against the spinning crankshaft.  1966 is to new for me!
                dale
                get’em wet!….don’t let’em set!
                #260293
                seakaye12
