Home Forum Ask A Member Waterwitch condenser replacement.
Viewing 5 posts - 21 through 25 (of 25 total)
  • #227862
    AnotherSteve
      I’m trying to identify what year this motor was made.
      Hopefully the earlier posted picture of the tank helps.
      It is a single cylinder.
      Stamped on the power head is: S53582
      Thanks for any ideas.
      Ah to be young and foolish again instead of old and still foolish.
      #227874
        Did you look at this link……?
        https://www.aomci.org/forums/topic/waterwitch-id-help-please/
          The number you gave is the serial number. If it’s a single cylinder, water cooled motor,
          you probably have the 1940 model 571.40
          1940 HP Cyl’s
          571.33 AC8001 – AC11565 Air Cooled .75 1 Made by Kissel
          571.34 DAC25001 – DAC28905 Air Cooled .75 1 Made by Kissel
          571.34A DAC25001 – DAC28905 Air Cooled .75 1 Made by Kissel
          571.40 S50001 – S56103 Water Cooled 2.75 1 Made by Kissel
          571.12 S37001 – S44106 Water Cooled 3.5 1 Made by Kissel
          571.23 T18001 – T23003 Opposed Twin 5.75 2 Made by Kissel
          550.75 (5810) Opposed Twin 8.5 2 Made by Johnson Mod
          AnotherSteve
            Once again thanks.
            #228066
              Disconnect the wie & use a meter to see what you get. Even if it is leaky it should function
