Home › Forum › Ask A Member › Wisconsin RBM Crankshaft removal
Viewing 11 post (of 11 total)
  • #83097
      PM T2, Did you recall if you found a serial number on your Wisconsin?
      Only possibility I’ve found is numbers stamped on the brass transom
      screw handles, with the numbers 4147 between the two screws.
      Did your transom screws have stamped numbers?
      Thanks.
