Home › Forum › Ask A Member › 1926 Elto Super G
- This topic has 82 replies, 7 voices, and was last updated 3 years, 5 months ago by
Tubs.
October 27, 2022 at 9:25 am #268329
Where is the blue smoke indicating an oil mix ?
Are you asking about his video or mine?
Tubs.A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
October 27, 2022 at 12:39 pm #268331Early in the message thread I mentioned this as high compression. One spark plug was very loose which allowed moisture to get in one cylinder. Once I got the jugs off, got the rings unstuck, and then reassembled it is very tight fitting with a lot of compression. I’ve thought about honing the cylinders, but everybody I mention it to advises against it. My thoughts have been that if it would just run for 5 min it would seat the rings and run itself in, but that is proving impossible. What are your thoughts?
October 27, 2022 at 1:56 pm #268332
I believe your’ thinking is reasonable about getting
it to run the first time. What do you think about trying this?
Getting one of these and using a socket that fits the
flywheel nut, and spinning the motor with a drill, with the
spark plugs out, to see if it will free up some. You might
also try it with just the spark plug in one cylinder at a time.
The compression might be helpful in getting it to loosen
up some if your drill is powerful enough to spin it.
Tubs.
October 27, 2022 at 2:42 pm #268333I’ve tried that with every drill I could find. Nothing has enough power to turn the engine over. I’ll pull it back apart and give the jugs and pistons a better cleaning. I’m a little afraid, but I will lightly hone the jugs.
October 27, 2022 at 2:58 pm #268336
If a drill wont spin the motor over with the plugs out
its bound up some where. While your convinced it is the
cylinders, and you may be correct, it could also be in
the drive shaft or the lower unit. It may be difficult to
determine with the cylinders off, but while they are,
rotate the motor to see if you can tell if it is in fact
the cylinders that is the issue.
October 27, 2022 at 11:10 pm #268348When I saw TFeltys video, I felt that the motor is too tight somewhere, not turning freely enough. ‘Too tight’ would lead to heat somewhere which would cause even more tightness and then motor stoppage.
October 28, 2022 at 12:42 pm #268360I rented a larger drill and got it spinning. It did free up a lot. If this doesn’t get it free enough, then I’ll pull the jugs off and hone them. Afterwards I tried to start it again and got closer than ever. It ran for a couple of seconds. With the jugs off the you can spin the motor with two fingers. There is no sloop in the bearings. I’ve pulled the lower unit apart, cleaned and greased it, so I know it is fine. The coil rebuild has good spark. The timer is tripled checked, and points / plugs spark every time. The battery is charged and good. I’ve got two which I have tested in parallel with no improvement. My carb was a problem and flooded quickly. After I got it apart and lapped the valve seats and cleaned it up it is working perfectly thanks to Tub’s cap and spring. I have good compression. With spark, fuel, and compression and it still won’t run. It tries to start every turn. I’ll focus this weekend on getting it more free.
October 28, 2022 at 3:58 pm #268363It’s possible that the rods are slightly bent and binding up when you reinstall the jugs. Try this: As you reinstall the jugs, before you bolt them up, see that the jug flange is parallel to the mounting face on the crankcase. There may be a little play, depending on wrist pin fit and rod fit on the crank, so check it at the limits: As you face the front of the motor, twist each jug lightly clockwise, then counterclockwise and make sure the differences balance out between the jug and the crankcase. I apologize if this isn’t clear, post questions if it’s not.
If you find that the binding is caused by bent rods, they can simply be bent back until the cylinder flange is parallel to the mounting face of the crankcase. The bronze rods are easily bent, particularly when trying to unstick a seized motor. Rods can also be twisted, actually very common in an un-stuck motor, but it’s gotta be really bad to cause a problem on a Ruddertwin.
Good luck!
T
October 28, 2022 at 4:27 pm #268365Did you clean the ring groves completely if not the new rings won’t be able to compress good enough.
October 29, 2022 at 9:04 pm #268433Ladies and gentlemen, boys and girls of all ages! I present my fully functional Elto Super G!
https://youtube.com/shorts/I4UgqwhexEw?feature=share
This reply was modified 3 years, 5 months ago by
Tfelty.
