Home › Forum › Ask A Member › Gift from my boss .. Lightwin
- This topic has 60 replies, 11 voices, and was last updated 4 years, 6 months ago by
Gregory Ciriello.
November 10, 2020 at 3:43 pm #220553
just cut up one of those sticky pads to size and put the felt side on the cam lobe.
November 10, 2020 at 3:58 pm #220554The points came with new felt ..
November 10, 2020 at 7:12 pm #220565The points came with new felt ..
Cool! Just clean up what ever grease you applied to the point shoes and cam. Don’t want that potentially fouling up the points later on. The light oil on the wick is adequate enough.
Cheers,
Cajun
November 12, 2020 at 10:20 pm #220738Working on the carb now .
I got a rebuild kit . Where do the plastic looking seals go ?November 12, 2020 at 10:22 pm #220740And how do you get the metal plug out of the slow speed ? needle casing ?
November 13, 2020 at 10:13 am #220761you punch in a small 1/8 hole with a drill but you just punch in DO NOT GO FURTHER then you take a small nail or pick and pry it out…. very easy job
when done…. install the new plug what I do is take a squarehead (Robertson ) screwdriver #2 and punch the center (dome) of the plug with a light tap enough to mark it
then I apply clear fingernail polish to seal the joint
see utube on doing a carb on a 9.5 at 5:22 min. same principle
https://www.youtube.com/watch?v=r-VTkOuSg00Joining AOMCI has priviledges 🙂
November 21, 2020 at 7:20 pm #221338https://youtu.be/Rs7I25bZ0dI
Got it back together .. Cleaned the tank and screen .. Really gunked up …
Used some 16-1 ratio fuel I had on hand . I assume 24-1 is correct for this motor ..
Only ran it a minute . I want to check/replace water pump/impeller .. Any tips on dropping the lower unit other than taking the bolts out and dropping ?November 21, 2020 at 7:26 pm #221339I also need to find a slow speed needle valve stem and knob .. The old one is broken off on the end ..And a new fuel shutoff valve ..
November 22, 2020 at 6:55 pm #221384Ordering stuff for lower unit .
Item 23 is not present on my motor . I assume that seals the connection to the water tube and I should order it.
Also trying to get the upper screw out of the lower gear casing . Is it ok to use heat there to try and break loose ? The end of the exhaust is broken . Will this hurt anything to run it like that ?November 22, 2020 at 7:05 pm #221385I have some parts if needed.
1 914 310 7086
Dave -
