Home Forum Ask A Member Impeller for Mercury Mark 75
  • #317201
    Cjbrill715
      So im well aware of the fact these impellers have been NLA for many years. I currently have a NOS impeller for it, but to be honest, I’m not too thrilled about a piece of rubber that is 70 years old. I’ve checked the web for info, very little to be had. My question is, is there a common 6 vane impeller with a 3/4″ bore that would work instead? If it involves a bit of trimming, I’m well suited for that, as I’m a machinist. The NOS impeller cost me $100, and that’s just not going to be sustainable. What do you guys typically do for direct reversing motors?
      #317242
        the folks at John’s old Mercury site may have a solution for you
        #317266
              With all these links my response would disappear for sure so I’ll post them individually. Brian Wilcox can make a replacement for some motors if you have the old center.  Email-  Baron0418@att.net  – the b must be capitalized
          #317267
                At the end of this recent discussion there are some comments about trimming down impellers. Being a machinist you may be able to bore out the center and make an insert.   https://www.aomci.org/forums/topic/1953-corsair-firestone-10-hp-impeller-swap/
            #317268
                  Here is a link to a discussion about impeller sizes. https://www.aomci.org/forums/topic/impeller-size-chart/
              #317269
                    Ferguson-Poole Inc may have impellers. link – http://www.fergusonpoolemarine.com/
