Home › Forum › Ask A Member › 1926 Elto Super G
- This topic has 82 replies, 7 voices, and was last updated 3 years, 5 months ago by
Tubs.
October 4, 2022 at 11:32 am #267069
Is there anything suspect in the carb? Do the two caps on the top of the carb come off? I tried, but they want to strip so I stopped. The mixing screw opens and closes. The poppets freely pop and spring back. Is there anything else to look at in it?
October 4, 2022 at 6:45 pm #267089
Yes the caps come off. Just some springs above the valves.
When it’s flooded and you shut the mixture screw all the way
the motor should start after a bit and run a little till all the
gas is burned up. Yours doesn’t. The carb has been pretty
much eliminated here. If there is an issue with your carburetor
you won’t know till you can get it to start. Unless there is
some damage, dirt is about the only thing that could give you
a problem. Not much to it.
Tubs.A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
October 5, 2022 at 8:13 am #267106
Misspoke about about the carb couldn’t be the problem. It still needs to control the air.
The fact that the caps are torn up is an indicator that someone who had no idea what
he was doing has been into this motor. You need to remove the caps and check they
are not cross threaded and they have gaskets, any indication the springs have been
meas with, or any damage to the valves or seats so the cant seal. If the valves don’t
seal it won’t start.
October 5, 2022 at 9:31 am #267112I had one motor (Caille or Wisconsin) that the poppet valve guide was so sloppy
I suspected was the possible a “no-start” issue. When a new poppet valve was
made with an oversized stem, it ran.Prepare to be boarded!
October 5, 2022 at 9:39 am #267114
I was running a Speedster, that wasn’t having any starting or running issues,
when I noticed one of the valve stems was missing. No idea how long it had
been gone. As I was 1400+ miles from home and the seat was also damaged.
I just put it back together. It ran fine for another 4 or 5 days before it started
to show signs that it was time to take it off the boat before I ended up rowing
back. In my experience there would really need to be some obvious damage
if it is the mixer. These aren’t really a carburetor.
Tubs.
October 5, 2022 at 11:07 am #267117Wow, that one was really messed up Tubs…… just shows how tough
Ole’s motor’s were!Prepare to be boarded!
October 5, 2022 at 2:11 pm #267126
I know I ran it at least 8 hours after I found the stem was
missing and have no idea how long it ran before that.
I was beginning to think it would last the summer but
when it started missing now and then I thought it best
to run something else as I’m not a big fan of rowing.
October 6, 2022 at 11:17 am #267160I had hoped to post a video of the motor running, however; I’m still not there. The condenser was definitely an issue. It sounds like a 2 cycle now when it hits. I never should have messed with the points. I’m having trouble getting them set back correctly. I get them set and tight, but they are somehow moving. I got so close that the motor actually ran for about a second. It wants to run!
October 6, 2022 at 10:36 pm #267189Maybe the iron case is moving, never mind. That would just affect the timing, not the point gap. I believe Elto recommends using shims to set the gap.
This reply was modified 3 years, 5 months ago by
HARRY D. NICHOLSON.
October 8, 2022 at 5:59 pm #267283I’ve taken the points from high gap to low and back and forth again. I’ve got it to run a second or two a few times but then that is it. Pulling the caps off the carb is all I can think of left to see what is going on in there. Can you show the tool / method that you got the caps off?
