Home Forum Ask A Member 1926 Elto Super G
Viewing 10 posts - 51 through 60 (of 83 total)
  • #267784
    Tfelty
      The cap that was closest to the choke was stuck and impossible to get off. I drilled it out and was able to get it off without damaging the threads. The valve seat on that one was pretty scratched up. I lapped them both using toothpaste and they actually look really good now. However, the carb I was able to find has a larger thread size and won’t fit. Now I am “dead in the water”. I need a cap and spring or another replacement carb. Anyone on this thread have any spare parts?
      #267795
        I have some caps but for a different carb. I’ll
        get you measurements tomorrow to see if you
        can use them.
        Check with Doug or Matt to see it they can
        provide you with a replacement carb.
        Link – https://www.oldoutboard.com/
        #267840
        Tfelty
          See attached pics for size of cap needed. I also sent a request to the suggested link.
          #267856
            #267861
            Tfelty
              I think the length difference is due to me measuring the height in the gap vs the top of the cap. I think that is exactly the cap I need.
              #267868
                You need a spring too?
                #267874
                Tfelty
                  Yes I do need it as well.
                  #267875
                    OK, PM me your address and I’ll send you the cap with a spring
                    along with some heavy gasket paper so you can make a replacement
                    gasket. I think you’ll find making this gasket an experience to remember.
                    You won’t owe me anything other than to pay it forward when you get
                    the opportunity.
                    #267878
                    Tfelty
                      I can’t even begin to thank you for your help! I really want to see this old girl running again.
                      #267886
                        Me Too.
                        I’ll try to get it boxed up and out to you today.
