Home Forum Ask A Member 1926 Elto Super G
Viewing 10 posts - 61 through 70 (of 83 total)
  • #267910
      Sent you P M.
      #267940
      Tfelty
        Great! Thanks in advance!
        #268015
        Tfelty
          I received the cap and spring today. Everything went together perfectly! Now to see if the carb was the issue. Fingers crossed!
          #268206
          Tfelty
            Well, not the update I wanted to give. The carb work has fixed my flooding problem. I know now that was a problem. It will keep popping, and then run for a couple of seconds. I thought I had it multiple times, but no dice. I just can’t think of what else to try. It is so close, but still so far away.
            #268217
              Check the points for tension and that the brass bar is not loose
              to the timer case and that there is good contact with that bar and
              the one the coil wire goes to. (Video Below). Also check your
              wires in the timer case for a possible short that occurs when the
              the motor is vibrating.
              How about a video of what it does as well as where the timer is set at
              when it almost runs.
              https://youtu.be/_AimIM5qdyI
              #268316
              Tfelty
                https://youtu.be/_t7Y1Wh08fU
                I can’t find anything wrong with the timer.
                • This reply was modified 3 years, 5 months ago by Tfelty.
                #268320
                  Your motor looks like it could be binding in part of its rotation.
                  I think I can hear it dragging – scraping on something when you’re
                  rocking it back and forth? Take out the spark plugs and rotate the
                  motor. It should be smooth all around. If not you need to find out
                  why not.
                  #268321
                    Look how free my motor is in this video.
                    Notice how it bounced back and forth on
                    its own when it doesn’t start
                    https://youtu.be/hKX0mZji7aA
                    #268322
                      I think it can, I think it can, I think it can……….. so close!
                      HARRY D. NICHOLSON
                        Where is the blue smoke indicating an oil mix ?
