Home Forum Ask A Member Jw-22 gearcase
Viewing 10 posts - 11 through 20 (of 32 total)
  • #226992
      Also, take the grommet out of the water pump housing and clean the corrosion out of the housing. The corrosion build-up between the housing and the grommet will cause the water tube to fit too tightly and bend the tube, rather than enter the grommet.
      #227013
      swamp yankee
        That much I did do already, got in there with a pick and a really small flat head, also had to fish out a phillips head screw I noticed in the water intake area forward of the pump housing. Hopefully have some time tomorrow to get back at that tube.
        #227014
        swamp yankee
          Also, should I grease the spline above and around the o-ring on the top of the shaft?
          #227026
            Yes, smear some grease on the splines
            Notice my previous post. That is why it won’t go together.
            #227027
              Frank is correct BUT please no grease on the top of the driveshaft & replace the o-ring, it holds grease on the splines. Run it dry & iy welds itself to the crankshaft….bad news
              Before retiring I serviced surgical tables. You would not believe cleaning makes assembly a breese. Take your time & get it right the first time.
              #227032
                To clarify, smear grease on the SIDES of the splines.
                #227091
                swamp yankee
                  Ok, so, got the water tube straight and everything went back on, gear oil in, prop on, then I find this in the box under the other prop, might this be the “pilot ring” I don’t recall it coming out, but it has been a bit. Hard to tell where it fits in exactly from the diagram if that’s what it is.
                  • This reply was modified 5 years, 2 months ago by Mumbles.
                  #227100
                    It might be the washer which goes between the prop and the prop nut.
                    #227106
                      yep !! jw21 parts show a washer between the nut and front of the prop
                      • This reply was modified 5 years, 2 months ago by JACQUES.
                      #227112
                      swamp yankee
                        There was a larger washer for that, been looking through the 67 and 59(donor motor) diagrams on marinengine, the lack of descriptions is not helpful
                        • This reply was modified 5 years, 2 months ago by swamp yankee.
