Home › Forum › Ask A Member › 1926 Evinrude NS Sportwin
- This topic has 62 replies, 8 voices, and was last updated 4 months, 3 weeks ago by
David Bartlett.
April 14, 2026 at 5:31 pm #315423
Today the magneto gods were in a good mood. I got the mag done on my Johnson AB-25, and I finished up the mag for this Evinrude. New condenser and plug wires installed.
I drilled the bakelite cover to allow running the wires through to the buttons on the military coil. Looks original from the outside.
You can see the solder joints under the cover. They got a bit of liquid tape after this pic.After all this I even had spark at the plugs. The lighting stuff will need to wait until I can run it.
David Bartlett
Pine Tree Boating Club Chapter"I don't fully understand everything I know!"
April 14, 2026 at 5:59 pm #315428April 14, 2026 at 10:06 pm #315456Pretty nice that you can retain that bottom cover to hide
the Military coil. Will have to change your handle to
Mr. Magneto! Keep up the good work, and we want to
see a video of both motors running.Prepare to be boarded!
April 15, 2026 at 7:24 am #315494Pretty nice that you can retain that bottom cover to hide
see a video of both motors running.Tom,
I’m going to think long and hard before I bring another Evinrude home! Seriously though, it is rewarding to make things work again. Now I have to figure out the gear lash in the lower unit.
David Bartlett
April 15, 2026 at 10:45 am #315508I started refurbishing the magneto today. I forgot to take pics. I will add some tomorrow when I resume.
David…..Can you post pics and text showing how you went about removing the Bendix laminates? Thanks! Great project there!
Chuck
Chuck,
I didn’t take any pictures of this process. Basically what I did is cut the laminates off close to the coil with a hack saw. Then drill down through the laminate as far as you dare. I used my trusty Walker-Turner drill press. Then get a long punch that fits the hole and drive the center laminates out. Sometimes they come easy, sometimes not! Then just work at the remaining laminates to get them out.
People seem to be getting better at the process. Looking back over older posts on here regarding the laminate removal on Bendix coils seems to indicate a high frustration rate and an even higher failure rate. I had been thinking it was essentially impossible.
Your success along with o couple of other posters seems to indicate that skills are getting honed a bit.
I wonder if all of the Bendix style coils available for sale today are created equal in this respect? Maybe there was more than one supplier for the so-called “Military Style” coil?
April 15, 2026 at 12:33 pm #315518I started refurbishing the magneto today. I forgot to take pics. I will add some tomorrow when I resume.
Chuck
Chuck,
I think you are correct. I have had a few of these coils that the laminates practically slipped right out. No rhyme or reason!
David Bartlett
April 15, 2026 at 12:35 pm #315519April 18, 2026 at 10:06 am #315738It runs! I am very excited to see this one run after the extensive magneto work. I still haven’t checked the lighting coil output but I am cautiously optimistic!
https://youtube.com/shorts/b3e10n4A4mE?si=h8XGxc8Qos9zMFmq
David Bartlett
April 18, 2026 at 4:48 pm #315772David – looks and runs great. Nice job!
"Every time you remove a broken or seized bolt an angel gets his wings."1 user thanked author for this post.
April 18, 2026 at 5:42 pm #315778Another mechanical marvel brought back to life. Good Job!
