Home › Forum › Ask A Member › Hard Starting / Will Not Idle 1981 4 HP Johnson Mdl. J4WCIC
- This topic has 48 replies, 6 voices, and was last updated 15 minutes ago by
Don.
November 12, 2026 at 8:10 pm #331818
Don,
Just for your information. This is the motor I robbed the Carburetor from. I call it my Johnny Cash Motor one peace at a time. I bought a box of parts for $40 and I was able to create this little monster. LOL!!😂
KentKent Cochran
“Tell Me And I Forget.
Teach Me And I Remember.
Involve Me And I Learn.”
Ben FranklinNovember 12, 2026 at 9:03 pm #331822can you confirm fuel flows up to the top idle circuit under welch plug ? remove the inlet needle & float firmly hand pump fuel to fill the carb while blocking the carb vent (usually above the carb face) fuel as only 2 places to go …… up the HS nozzel and the idle circuit path to the top
with the welch plug out……. check to see if fuel makes it up the feeder channel & with the idle needle backed out… fuel should saturate the chamber under the plug and drip out the small holes .
just a suggestion… up to you …… up the creek that is what I would try
November 12, 2026 at 11:19 pm #331828Jacques, I will try that next. I will be out of pocket for a couple days, but will let you know how that test goes.
Thanks, KentKent Cochran
Ben FranklinNovember 13, 2026 at 7:40 am #331839Sounds good in the video, is this the original or substitute carb? And yes, that point timing looks retarded, would be very interested in knowing the gap they are set at.
I may have a spare carb for this engine, will have a look. Let me know if you want it. Don
November 13, 2026 at 8:36 am #331840Don,
This was the substitute carb. The gap is set at .o20. Maybe I am not lining up the cam with the points arm correctly. I will take a picture of the cam and points to show how I am lining them up.
I would be very interested in the carburetor you may have. I would love to see this little motor run again. I don’t want to give up yet!! 🤔
Jacques, Can I use water with food coloring in it instead of gas to run the test that you are recommending?
I guess sometimes the simplest motors can be the most challenging!!! Thanks, KentKent Cochran
Ben FranklinNovember 13, 2026 at 9:35 am #331843OK Kent, the carb I have is from a newer engine, but will remove it and take pictures for you….
November 13, 2026 at 10:08 am #331845Don, here are some pictures of my carburetor with part #’s
Kent Cochran
Ben FranklinNovember 13, 2026 at 10:14 am #331850One more picture with carb on the motor.
Kent Cochran
Ben FranklinNovember 14, 2026 at 11:10 am #331939Found one carb, but it is the metal bowl type for the little engines, so it has no fuel valve. It will work fine though but you won’t be able to run the carb bowl out. I would say put a valve in the fuel line, but there is no access to it with the lower cover installed. Will keep looking for a plastic bowl carb with the shut off valve. Don
November 14, 2026 at 6:10 pm #331998Ok thanks,
Will the bowl off my carb. Fit the one you have?Kent Cochran
Ben Franklin -
