Home › Forum › Ask A Member › Hard Starting / Will Not Idle 1981 4 HP Johnson Mdl. J4WCIC
Viewing 10 posts - 21 through 30 (of 49 total)
  • #332045
      Ok thanks,
      Will the bowl off my carb. Fit the one you have?
      No, the plastic bowl won’t fit on the carb I have.  There is an extra internal passage on your carb where the fuel flows from the inlet on the bowl to the needle/seat.  The fuel inlet on my carb is a cast in nipple on the upper carb body.   Like I said, my carb will work, but you won’t be able to shut off the fuel flow.    I think your carb is worth having another look at it, and sealing up that brass idle tube into the body.
      #332062
      Kent Cochran
        Don, do you mind sending me the exact details on how to add the sealer to the brass idle tube? For my clarification, you are talking about the brass tube that runs up through the middle of the high speed nozzle that is not removable correct? Thanks for all your help, Kent
        Kent Cochran
        “Tell Me And I Forget.
        Teach Me And I Remember.
        Involve Me And I Learn.”
        Ben Franklin
        #332098
          not to dispute the above…but  strongly suggest you analyze the problem deeper regarding that delicate idle tube and  circuit ….. before clogging it. maybe look for an obstruction .. (not introduce one !!!) .  air blast it after a good shot of carb cleaner  etc… carbs are very simple devices and unless some  orifice is damaged or … plugged they can be troublesome  jmho mind you
          #332160
            You could use a syringe on the idle pick up tube to see if fluid seeps out between the top of the tube and carb body.   He has the lead shot removed from the top of so you could always check for excess loctite seeping between the tube and casting before replacing the new lead shot…
            #332194
              Kent, sorry, I wish I could find the original service bulletin with instructions for this procedure, but can not.  Pictures are surely worth a thousand words, my words anyway.
              The first thing to do is to spray the carb with electric cleaner or something that will remove any oily residue.  Next, invert the carb body and clamp it in a vise in a position/height where you can easily see inside the throat with the choke open.  I would probably spray a little of the loctite primer in the area where the brass tube passes through the top of the carb body.  Next, put not even a drop of the strong loctite on the end of a tooth pick and just touch it to where the brass tube passes through the top of the carb.  The primer will automatically “wick around” the brass tube filling any voids (air leaks) that might be present.  I would probably let the carb sit in this position over night to ensure the loctite dries completely.   You have the lead shot removed already, so you could peek inside from the top to ensure there is no excess loctite in that passage, once everything has dried.
              Again, this is a “long shot”, but occured often enough for OMC to publish a bulletin.
              You mentioned replacing the low speed needle, tell us more about why you did that.  Are both needles the same shape/contour?
              I know I mentioned an intake manifold issue before, but it would seem as though this is unlikely seeing that the engine ran better with a different carb.
              #332202
                fwiw found on ai …
                OMC’s recommended corrective procedure is:
                1. Remove and clean the carburetor.
                2. Invert the carburetor body.
                3. Fill the idle circuit with isopropyl alcohol.
                4. Check whether alcohol leaks around the brass emulsion tube.
                5. If it leaks, dry the area thoroughly and apply one small drop of OMC Ultra Lock (P/N 388517) at the leak.
                #332209
                Kent Cochran
                  Guy’s
                  When I got this motor the low speed needle was missing.
                  Jacques, should I still run the test you recommended by taking out the float, seat and Welsh plug before I try these other suggestions? I will send you guys some pictures of the brass emulsion tube on high speed nozzle side and low speed side of the carburetor. So that I am 100% sure I put the ultra lock in the correct spot. If it comes to this procedure.
                  Thanks, Kent
                  Kent Cochran
                  Ben Franklin
                  #332214
                    at this point try anything no harm will come of it  only a happy ending .   fuel must reach the top idle circuit to idle properly
                    (1) How Does a Carburetor Work? | Theory of Operation – YouTube
                    #332228
                      OK, so there was no needle valve when you got the engine/carb.  I pulled the needle valve out of my carb, doesn’t look quite the same, but might not be the same carb as well…  Nonetheless, like others have said, did you try threading the needle valve all the way in with the core plug removed in an effort to ensure the needle fits completely into the hole in the mixing pocket?  I do see the packing nut, along with some packing washers in your picture so am assuming there is no air leak through the packing nut.   Perhaps this is a just an issue of the needle valve not fitting properly into the carb.
                      #332256
                      Kent Cochran
                        The needle seems to be seated. It has no movement to it. It turns easily and it feels seated.
                        Here are bunch of pictures I took with my bore scope camera to help you see what I see.
                        Kent Cochran
                        Ben Franklin
