Home › Forum › Ask A Member › Hard Starting / Will Not Idle 1981 4 HP Johnson Mdl. J4WCIC
Viewing 9 posts - 41 through 49 (of 49 total)
  • #332413
    Kent Cochran
      All,
      I ordered the original low speed needle this morning #388981 $16.
      Here is the results of the flow test. When needle is seated there is no flow into Welch plug area. I do see flow up through the high speed jet into the carburetor throat.
      Here is a short utube video with the slow speed needle backed out 1 1/2 turns. I can’t post it the file is to big. If you want to watch it. I labeled (1981 4 hp J4WCIC Carburetor Flow Test)
      Please look over the video and make sure I am running this test correctly. No leaks around the packing nut.
      Thanks, Kent
      Kent Cochran
      “Tell Me And I Forget.
      Teach Me And I Remember.
      Involve Me And I Learn.”
      Ben Franklin
      #332452
        Watched the video.   Did you try with the needle closed off as well?  I am a bit confused though.  You are injecting fuel into the carb bowl, but the float should prevent the fuel from running up the idle tube and into the mixing pocket.  Perhaps you did not have the float/needle installed.
        #332457
        Kent Cochran
          Yes, I did take out the float and seat, then reassembled the carburetor. Jacques had mentioned earlier in the post to run the test that way. I also ran the test with the low speed needle seated there were no leaks into the welsh plug area. Did I block off the other passages correctly with the cork plugs?
          Kent Cochran
          Ben Franklin
          #332458
            needle must be open for fuel to enter the welch plug area  find out  why it  does not reach it .. the alternative is the remove the needle inject water mix  in the needle  pathway while plugging the small neele hose in the welch chamber     your mix  should flow back down to the carb bowl.  if it does not the idle circuit is plugged up    jmho
            #332462
              Q
              Click on “Share” and you’ll get a link to your video that you can post. Link – https://youtube.com/shorts/n0beGG8oRPs?si=8KJH1N4u80W5CsN_
              Share
              #332467
                Don . i had suggest REMOVING the float and/or inlet needle  to purposely flood the bowl and allow fuel/color liquid to flow UP to the idle chamber with  idle needle OPEN  for purposes  of checking  that the fuel pathway is allowing fuel to reach the top chamber  (see video from tubs…)   if fuel can’t reach the idle chamber  the engine will not get what it needs to run (idle)  properly unless running at high speed to suck  its fuel supply from the  high speed  carb circuit .
                found this
                https://www.youtube.com/watch?v=GPKPlMojvec
                #332487
                Kent Cochran
                  Thanks, Tubs for sharing my video. This was only my second video to try and post.
                  Guys, did I not run the flow test correctly? Any thing else I need to try?
                  I did order another slow speed needle that shows to be the original part #388981.
                  Thanks, Kent
                  Kent Cochran
                  Ben Franklin
                  #332490
                    found this
                    Makes sense, easier than trying to inject fuel into that tiny brass tube!
                    #333068
                      Kent, did you try the engine again?   I had one more thought, but don’t think it applies to your carb.  Some of the newer carbs have a rubbery type needle valve tip seal that fits deep inside.  I don’t think your carburetor used this piece though, because your carb still has the conventional packing/nut set up that seals that area from air leaks.
                      Item number 38:
                      https://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1972&hp=65&model=65272S&manufacturer=Evinrude&section=CARBURETOR
