Home › Forum › Ask A Member › Hard Starting / Will Not Idle 1981 4 HP Johnson Mdl. J4WCIC
- This topic has 48 replies, 6 voices, and was last updated 15 minutes ago by
Don.
November 16, 2026 at 5:23 pm #332262
More pictures.
Kent Cochran
“Tell Me And I Forget.
Teach Me And I Remember.
Involve Me And I Learn.”
Ben FranklinNovember 16, 2026 at 6:50 pm #332278OK, don’t see any issues here. Have you tried threading the needle valve all the way in without the packing number to see if the tip seats completely into the mixing pocket?
November 16, 2026 at 10:31 pm #332293Yes, before I put in new packing washers and a nylon washer, I ran the needle all the way in and it felt like it seated just fine. It had no wobble to it.
I wonder if there is something different about the seat I ordered and the actual part # in the manual.
I looked on Marineengine.com, see pictures below.
I ordered seat #431634 I ordered it from eBay because it was cheaper. This needle is not stainless. I believe it’s chrome plated.
I just found another seat on eBay that has the same part # as this motors parts Manual #388981. Do you think I should order it? What are your thoughts?Kent Cochran
Ben FranklinNovember 17, 2026 at 11:06 am #332352Reminds me of a 15HP Gale a few years back. I had replaced the slow speed needle. all seemed fine except as you are finding….turning the needle had absolutely ZERO effect on the engine’s running.
Turned out that the replacement needle was incorrect; a bit too short. It never made it’s way to the seat.
There are no part numbers on needles. People selling on e-bay sometimes take their best guess as to what they are selling when parts become separated from their original packing
November 17, 2026 at 11:40 am #332358i think the important aspect of the idle needle is that it is suppose to stick out of the control orifice and can be seen under the removed welch plug when properly seated in. if it does I would presume whatever little fuel could bypass it would not be critical enough to create the hard starting problem since some …fuel is needed anyway to be sucked down the 3 drip holes.
jmho
November 17, 2026 at 12:06 pm #332363I do see the tip of the idle needle from inside the Welch hole plug when seated, but it does not stick out into the Welch plug hole.
Kent Cochran
Ben FranklinNovember 17, 2026 at 1:58 pm #332378on all my older 4hp the needle protrudes slightly maybe 3/32 … just make certain NO fuel goes by when closed (seated) . did you check if el flow from carb bowl reaches upper drip chamber via the needle unscrewed 1.5 turns ( tested with float and inlet needle taken out ?)
November 17, 2026 at 2:11 pm #332379No, but I am ready for that test. I was asking you earlier in the post if I could use water and food coloring for the test instead of fuel. So I can run the test on my work bench.
Kent Cochran
Ben FranklinNovember 17, 2026 at 4:51 pm #332391Yes, before I put in new packing washers and a nylon washer, I ran the needle all the way in and it felt like it seated just fine. It had no wobble to it.
I just found another seat on eBay that has the same part # as this motors parts Manual #388981. Do you think I should order it? What are your thoughts?OK, so 388981 is the original part number for the needle, you ordered the updated part from ebay. I find it interesting that you say that you can see the needle in the hole when seated but it does not protude into the mixing pocket at all, they usually will protrude into the mixing pocket 1/32-1/16″ or so. How much do they want for that original needle on ebay? I would say go for it if it is not expensive.
In the meatnime, you could surely test the current closed needle with a water/food coloring mix as you mentioned. Use a tiny plastic syringe to inject the colored water up the idle tube and see if it floods into the mixing pocket. If so, then it would seem as though the needle is not seating properly when closed.
November 17, 2026 at 7:45 pm #332412colored water wont hurt carb aluminum
